i tried searching but cant find what im looking for
im buying the apexi ax5370-p25 turbo kit that is advertised on here. http://www.skylinesaustralia.com/forums/Ap...-S-t226760.html
it comes with all the lines etc i believe.
its going to replace a rb25 turbo on my r32 rb20.
if i decide to do the install myself its all got to go smoothly & be a 1 weekend job, so im looking to get some info on the oil & water lines before i start.
where does the oil feed line from the top of the turbo go to on the block? is it easy to get to?
i think i can see 1 water line go from the turbo to around the back of the head, looks to be a bit tight in there for room..
where does the other water line connect to from the turbo? is that one easy to get to?
thanks
Edited by norwest_rumbler
https://www.sau.com.au/forums/topic/226952-turbo-install-oil-water-lines/
did mine in 5 hours! same turbo same car..
back of the block water line is a mungrel to get too...
u need a spacer for the manifold! to puch the lager compresser out abit. prob 5mm..
need a custom heat shield!
other than that was a fair easy job!
thanks for your reply, yeah i saw yur thread looking for similar help.
a spacer, yeah i just noticed my rb35 turb is just touching the stock mani heat sheild, so i was wondering about that..
did yours come with the apxi lines? if so does it connect to that water line at the back of the head?
what about the other lines are they easy?
hey yeh i didnt get to the back one.. just connected to the existing one that goes there then heat wraped it.. yeh i got the full kit..
the others are easy just abit fiddly! but iff u pull everything off and drop the dump u should be fine!
nope i had to chase one down!!
and i got an 8mm first and studs were too short found 5mm was better! had to grind a very small amount of the comp cover were the apexi logo is to fit it! im talkn likr 3-4 mm! so not alot! u will c when u line it up!
thanks, like i say i want to do this job first time in one weekend, so thats great info.
im getting everything the seller used to install in his 32 so it should come with a spacer etc, but i will check now.
cheers
hi Adrian
hi just found this pic of yur turbo, i can see where you have ground down the comp cover a bit for clearance, but i cant really see the spacer?
is it in that pic? cause the studs look like they are poking thru the flange/nuts, as much as my rb25 turbo?
cheers
http://www.skylinesaustralia.com/forums/Tu...;hl=ax53b70-p25
haha yeh there is a 5mm spacer.. had to c! but was just enough to push it out so i didnt have to grind too much away!
its more the fact of clearing the comp cover than were the manifold joins!
yeah i understand what the spacer is for, but in that pic i can see the turbine t3 flange, gasket & what looks like the exhaust manifold flange - or is the 2nd gasket & 5mm spacer there?
also the studs have about the same amount of thread showing as my stock setup (suggesting no 5mm spacer?)
cheers
4k sounds about right from me guestimating from other charts ive seen that read road speed not revs (around 100kmp/h in 4th gear)
tbh 280hp atw at 17psi sounds a bit low to me, but could be the dyno or other factors?
im making 250 now & im hoping for 50+hp more not just 30?
are you running a cat & what dump is it?
cheers
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
