There are a few type of write off's.
1) Where your car is obviously too damaged to repair
2) Where the value of the repairs is a certain % or more of the value of your car.
I believe a repairable write off can be road registered. You just need to go through all the appropriate steps for registration and the authorities to check that the car is safe for the roads.
https://www.sau.com.au/forums/topic/227011-write-off/#findComment-3996217
writes off can never be registered - parts only
repairable writeoffs can be registered after inspection however you must have all receipts for parts that are purchased for the repair or they wont sign off the paperwork. I believe the registered writeoff scheme is more related to reducing the use of stolen parts, then the quality of the repairs. cost of the inspection is about $450?
theres a formular they use to decided if its a writeoff, or repairable write off. Usally writeoffs have bad structual damage, and reapirable writeoff dont but the insurance company would have to pay too much to fix it so they just pay it out.
also if a car is more then 15 years old then they dont get listed as a writeoff / repairable writeoff so better to buy something 1993 and older as you dont have to go thru the above bullshite.
This is from my experience and not in anyway garanteed as correct
https://www.sau.com.au/forums/topic/227011-write-off/#findComment-3996501
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
