Item: RB25 engine/box/loom ecu package
Age: out of a 96 S2
Condition: very good compression around 155 through all cyls
Price:$2900o.n.o
To Fit: (What car) what ever you want really :P
Contact:me on here
Comments:only missing turbo and fan, but see below, has approx 120K on the clock timing belt changed at 108, will come with new waterpump,
Item:Sliding performance High flow RB25 turbo
Age:around 8 months since build
Condition:excellent no shaft play what so ever
Price:$700
To Fit: (What car) Rb20?25
Contact:me on here
Comments:i believe it uses a vg30 rear housing, the ultimate in legal turbs has made 264rwkw!!!
Item:Greddy STYLE plenum and 80mm billet throttle body
Age:NEW
Condition:good
Price:$440
To Fit: (What car)RB25
Contact:me on here
Comments:the plenum has had the adapter for the throttle body already welded on!
Item:Splitfire coil packs
Age:unsure
Condition:very good!
Price:$400
To Fit: (What car) Rb25
Contact:me on here
Comments:these are to suit S1 i was told but i also have the s1 coilpack loom, which you can use on the S2 if u use the s1 loom.. anyone confirm?
Item: RB25 cometic metal headgasket 1.3mm standard bore
Age:new
Condition:new
Price:$260
Contact:on here
Comments:ummm yes its a headgasket...
Item:RB25 stainless mani
Age:new
Condition:new
Price:$150
Contact:on here
Comments: looks to be a ebay special comes with turb to mani gasket
Item:greddy timing belt
Age:new
Condition:new
Price:$140
Contact:pm on here
Comments:
any questions just hook me a pm
Cheers,
Danny
Edited by shy_s6
So whats the go with separating? will you on hte engine package?
if so, you have my pm on what im interested in
i want the box so if u want the engine were both in adel so we can work something out?
hehe
    • The frontend wouldn't go low enough because the coilover was max low and the upper control arm would collapse into itself and potentially bottom out in the strut tower. I made a brace and cut off the kingpin and then moved the upright down 1.25" and welded. i still have to finish but this gives an idea. Now I can have a normal 3.25" of shock travel and things aren't binding. I'm also dropping the lower arm and tie rod 1.25".
    • Motor and body mockup. Wheel fitment and ride height not set. Last pic shows front ride height after modifying the front uprights to make a 1.25" drop spindle.
    • Here's Logans Silvia with R32 Drivetrain, mine will be slightly lower (more angle). He was constantly blowing the RH axles at around 16deg. I want to avoid this.
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
