its really the best he can do, ive heard a few storys with probs at tillbrooks which really werent makrs problem but due to them being his employee's, mark is a good guy, (flew to melb with him for the first drift nats all went to the cas n had a crazy night along with stanic and denzo) good bloke but yer working on his own will be much better!
Edited by shy_s6
Mark is a top guy!! :P
Had good dealing with him when ever he worked on my cars..He hasn't had the best luck with employee's and I am glad he has made the decision to go back to basics :D
Wish him all the best! :banana:
yeah you paid mark to do work on your car and the work got done by the workers thats what workers do when you pay them :/ if he did all the work him self he would never go home so dont be so mellow dramatic
Edited by Bunny33
if his work was so good why is he closing?????? also if mark was a man of his word he would have done as he promised and he DIDN't! so why don't you go and voice your "un educated" opinion elsewhere. oh by the way why don't you go read a dictionary.
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
