Emanage Ultimate (was only used for about 3 months)
+ universal harness
+ map sensor & map sensor harness (brand new)
+ AFR input harness
cost me $1050 sell for $700
also have innovative LM-1 wideband + RPM converter (was only used for about 3 months)
cost $500 sell $400
or buy both for $1000, everything you need to tune your car yourself
Brisbane
some pictures, why can't I edit my first post??
also have a mdf parcel shelf for 6x9's fits in the back really well
$30
also have gizzmo boost controller, I accidently broke the wires off on the solenoid coil, but I found a place that will sell me a new one for $35 + gst
so will sell for $200 and you get new solenoid or $250 and ill get the solenoid.
Edited by SevenAngryPenguins
I have a Power FC as well $1200, I've had this for less than 12 months and actually used it for only about 4 months, hand controller is in as new condition.
As a note I had this in my car but it stopped working after I installed new injectors, so it was sent to Japan for repair under warranty however it was tested by apexi and they found it working 100% and said problem was with the car.
but yeah if it doesn't work ill definitely refund.
this no editing posts sucks balls.
also since i didn't add its for ecr33
how did the e-manage go on your car?
like did it run well and stuff
and did you need the map sensor & map sensor harness and
AFR input harness to install and run it ?
I had highflow turbo and s15 injectors and it ran really well never had it dynoed but was probably making about 300hp atw, it took a lot of time playing around with the laptop to get it right though since I tuned it myself on the road. I wasn't using the map sensor at the time but was just about to (before I got t-boned) stock afm maxes out really early so it gives you crappy resolution for tuning. For the price its a sweet computer but a lot of stuffing around with the initial setup compared to say a pfc which is virtually plug and play
  • 4 weeks later...
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
