Make: Nissan
Model: Silvia K's
Milage: 140,***
Transmission: Manual (close ratio s14 box - has had manual conversion)
Colour: black
Complied? Yes
RWC supplied? N/A
Currently registered? Yes. Rego runs out 9/9/08. If not sold by then i will re-register.
Price: I bought for $8500 with 12 months rego. But am open to offers
Contact: Nick - 0410-803-199 - [email protected] / [email protected] (during business hours)
Comments / Modifications:
Hey guys,
Well i've had this car 12 months, and hardly any of you have ever seen my car lol.
But its time for me to let it go. I just can't afford to keep it. its due for a service which i can't afford, and it does have a lot of issues that would need to be fixed up. I rushed into buying this vehicle, and bought it for $8500 with 12 months rego. Rego is coming up in september so if it doesn't sell by that date, rego will be put on it.
This was bought off a forum member on SAU. I will not disclose his user name as i do not want to slander him. But he is extremely dishonest and regret buying this vehicle.
**1991 s13 silvia k's sr20det (Non-HiCas + Non ABS)**
-Modified close ratio 5speed s14 gearbox.
-140XXX klms.
-400hp fuel pump
-Sard adjustable fuel pressure reg (rising rate)
-Custom oil catch can
-Rubber vaccume hoses replaced with simota Silicone hoses
-Annodised oil temp sensor mounting block
-new oil hoses and annodised oil fiitings on tubo(new/all speedflow fittings used)
-Top mounted T3 Bush Bearing turbo - Also found out (after buying the car) that this is also a cheap shit EBAY turbo
-Stainles steel top mount tuned length exhaust manifold - This is an EBAY Manifold - which i was informed of AFTER buying the vehicle - It has been rewelded by Castle Hill Exhaust and they informed me that it was cheap shit
-38mm external waste gate with screamer pipe
-3"cat back exhaust
- Non Turbo front bar (no longer has vent for side mount)
-Alluminium radiator overflow tank
-Front mount intercooler kit fitted
-Battery relocated to the boot
-Earth kit fitted to engine
-32mm rear sway bar fitted
-BLITZ boost pressure,exhaust temp,oil temp and water temp gauges with memmory recall(fitted - some of these guages aren't hooked up tho)
-GReddy boost gauge with adjustable warning and memory recall
-FIELD digital fuel adjuster - Its there - not sure how to use it tho
-S14 ignition coils fitted
-DNA motorsport boost control valve (not fitted)
-Electric thermofans fitted
-Kenwood Double-din headunit with mini disc - not fitted, but can include if you want - vehicle currently has no sound system
-JBL 4x6" front speaker 200watts each
--Fusion wiring fitted
-New battery (heavy duty bosch)
-Interior retrimmer in creame & Black with black stitch
-Momo steering wheel
-Momo boss kit
-Apexi turbo timer
-New good year eagle NTC5 tyres fitted- 4months old.
-series 1 s13 silvia headlights fitted
-Serviced every 5000kms using genuine nissan parts
-Exedy extra heavy duty clutch with 1200kg pressure plate
-Power windows
-Power mirrors
-Climate control
-Central locking
-Power antenna
-Tinted windows
PROBLEMS:
-Oil leak from gearbox tail shaft seal - Can include NEW genuine seal
-Small dent behind drivers door
-Paint chips on rear bar
-Damaged rear quarter due to being hit in a car park (has been sprayed over)
-Various small dings and scratches
-Bonnet needs respray
- There is some rust starting to appear near boot
- Windscreen/door seals do look a bit ratty, however do not leak.
- BARE wires in engine bay. There's alot of shotty wiring. Also done by previous owner
- Reverse lights not hooked up after manual conversion
**NOTE** - Vehicle was in minor accident. Has been fully repaired by Western Smash Repairs. Due to the accident, front bar and LH front quarter panel have been replaced/resprayed.
Thanks
Nick
Images:
https://www.sau.com.au/forums/topic/228983-91-s13-ks-sr20det/
hey there, would u be intrested in a swap with a pulsar n14 sss 92, with full custom red interior, bucket seats, lsd, g4 adjustable suspension, sr20, k&n pod, exhuast,
17inch black gestalt rims, rego, tints, big system etc? pm me if ur keen, baby blue coulur, wingless
  • 3 weeks later...
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
