Item:JL AUDIO A4300 4ch Amp
Age:Brand new, only opened box to inspect
Condition:Brand new, only opened box to inspect
Price:$450
To Fit: (What car)
Contact:Mario 0430 129 882 or pm, or email [email protected]
Comments:
Amp is basically brand new, I only opened it to look at it, all paperwork and original wrapping is inside the box, paid $679 at JB Hifi a few months ago, was going to use it, but already have my old audio gear to use, Sydney location, pickup is preferred but can post at buyers expense.
specs of the amp
A Series 4-Channel Class AB Car Amplifier
RMS Power Rating at 14.4V:
4 ohms: 70 watts x 4 chan.
2 ohms: 110 watts x 2 chan.
Bridged, 4 ohms: 220 x 2 chan.
RMS Power Rating at 12.5V:
4 ohms: 45 watts x 4 chan.
2 ohms: 75 watts x 2 chan.
Bridged, 4 ohms: 150 x 2 chan.
Max Power Output: 880 watts
Absolute Symmetry? Class A/B Circuit
Remote bass level input (remote level control sold separately)
LED power and protection indicators
Tuned Bass EQ (0-6 dB bass boost at 48 Hz)
Differential-Balanced Input Topology (For superior noise immunity)
Pass-through type Preamp Output
Variable low-pass filter (50-200 Hz, 12 dB/octave)
Variable high-pass filter (50-200 Hz, 12 dB/octave)
Frequency response: 10-25000 Hz
Dimensions: 13.8" L x 9.25" W x 2.5" H
4-gauge power and ground leads recommended. Contact us for information regarding a discount on a select amplifier kit when purchased together.
1-year Sonic Electronix warranty
***Will get proper pics ASAP***
https://www.sau.com.au/forums/topic/229510-jl-audio-2008-model-a4300-4ch-amp/
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
