we are thinking about selling Brendon keenans silver ke70 as we are thinking about a new project for 2009 if we cant egt the price we are looking for it we will keep the car and progress it even further car goes like this
Motor/ computer/ fuel
Sr20det out of a Nissan Silvia (s13)
Ae86 Toyota sprinter cross member with custom built engine mounts
Custom gearbox mount
Ca18det gearbox with sr20 bell housing
Custom hydraulic clutch set up
Garret 2871rs turbo
GCG turbo’s manifold
48mill external waste gate with screamer pipe
610cc injectors
Haltech e6x computer
Custom intercooler with custom cooler piping by hypertune
After market s13 radiator with thermo fan
Modified radiator support
Heavy-duty clutch
Bosh 910 fuel pump
Custom fuel surge tank with lifter pump
Custom fuel lines
Suspension
Toyota sprinter front brakes
Toyota sprinter front struits
Toyota sprinter power steering arms
Sigma control arms
Ra 40 Celica tie rod ends
Battle star roll center adjusters
Ford Capri front springs
Mr2 short stroke front shocks (sw20)
Suzuki sierra short stroke rear shocks
Custom ford au rear springs
Interior
2 fixed back bucket seats on custom rails
Boost gauge
Oil temp / water temp gauge
Full cage
nardi steering wheel
Diff and exhaust
3-inch mandrel bent exhaust
t18 diff housing with ra40 centre and ra40 axles
custom 1 peice tail sharft
Battery relocated into the boot in battery box
Exterior
vertex ae86 body kit by EMPIRE AREO BODY KITS
Custom flared guards
15-inch by 7.5 ssr meshies –3 offset
The car is tuned by Adam from Jem makes 208 kw at the wheels on 16 pounds of boost
car is located at gymea about 15 min from cronulla nsw
Price $13000 ono
contact details 0404350919 if i dont answer send me a msg and ill return ur call
can make the price less with out parts
https://www.sau.com.au/forums/topic/229603-the-gs-silver-ke70-for-sale/
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
