just out of interest i would like to find the specs for the rb25 turbo.
comp wheel outside diameter mainly (60mm??) but any others you know would be great as well.
yes ive tried searching & googling quite a few times but cant seem to narrow the search down or find anything.
thanks
Edited by norwest_rumbler
https://www.sau.com.au/forums/topic/229707-rb25-turbo-wheel-sizes/
Thanks Mark, that is great info!
wow the rb25 turbo is alot bigger than i thought, 67mm comp wheel.
http://www.skylinesaustralia.com/forums/in...t&id=143281
this has been bugging me for months, not knowing some basic sizes for it.
just hope my apexi turbo im fitting soon is a big enough upgrade :|
cheers
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
