Item: HKS 256 Intake/ HKS 264 Exhaust Camshafts
Age: Purchased a few months ago and were in car for a few dyno runs and a bit of driving around town
Condition: As new, not a mark on them
Price: $800 delivered
To Fit: RB25 Series 1 or Series 2 (Retains the VCT on the intake side)
Contact: Just PM on here or reply to the topic
Comments: Cost me over $900, Slide sells them for $480ish delivered and hoping to get most of my money back :) My cars setup for some reason didn’t like the cams, it ran fine with them but we just couldn’t get the power we wanted. We narrowed it down to probably being a valve train issue or something so I bought valve springs due to planning to rip the head off. At the moment I can’t afford to do that so selling the lot and maybe ill attempt it again one day if I can be bothered.
Item: Performance Valve Springs
Age: Purchased a month ago
Condition: Brand new, never taken out of box
Price: $290 Delivered
To Fit: RB25
Comments: Purchased these through work at Autobarn for my staff price of $290, was going to go through with it but now im not. Ill do them for the same priced but delivered. If i can't sell them i'll just hang onto them incase i do the cams in the future again.
Item: Standard AFM and plug
Age: 1996 Model Skyline
Condition: Perfect working condition
Price: $100
To Fit: RB25
Comments: I run a microtech ECU so no need for this.
Item: Standard R33 GTST RB25 ECU (Manual)
Price: $100
To Fit: RB25
Item: Standard R33 GTST Bov
Price: $50
To Fit: RB25
Comments: No need for this.
Item: Standard R33 GTST Plenum (Has been sand blasted to as new finish)
Condition: As new, had it sand blasted inside and out so ready to be polished or what ever else you may need it for
Price: $80
To Fit: RB25
Feel free to ask any questions you want or if you want more pics.
Thanks guys.
Hey sorry guys, valve spring and HKS cams are no longer for sale. Im going to attempt it one last time by taking the head off and installing them. F***ing cars, so over them lol.
Plenum, ECU and AFM still for sale though if any one is interested.
Ok change of plans for the final time. After much discussion with my tuner, we are going to rebuild the head but he doesn't want to use the HKS cams so i am giving up on them and going to try a set of Poncams and see if they work. They are back up for sale if any one is still interested or will do a straight swap for Poncams (the HKS ones are dearer so you would be getting a better deal).
Sorry for mucking people around.
Thanks
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
