hey dude, i was going to do it with a big stainless steal one, while ur at it u should put the pod in the front bar and then uve got proper cold air, u shouldnt loose ne power as long as u stick with the same or slightly larger diameter piping.
A guy I know in SDU has had this done, he hasn't lost any power, if anything I think he has gained a few kw, and he has a bit more induction noise.
His car is basicaly stock, just with a pod and no cold air intake, he is running mid to high 15's for the 1/4.
if your get the intake pipe to be the same diameter as the stock one, there shouldnt really be any ramifications at all.
I didnt know what the thing off teh side of teh intake was either :-?
gaining or losing power would be from the result of changing the size of the diameter of the pipe.
If the pipes are cheap and easy t make, maybe consider making 2 or 3 in different sizes and determine if you can feel any difference's.
i thought the black box off to the side of intake was a resonator box
to quieten down the intake noise there is no hose off the engine for this to be a oil catch can , the hose off the back goes to your intake manifold collector.
you could replace it WITH A ALUMINIUM OR STAINLESS one but your induction noise would be louder ,actually sounds quit good the one i heard
eryc
no down side i liked it sounded good
he used a one piece aluminium one for a comadore and cut it into 4 parts and joined it back together(so all the bends suited the skyline) with silicon joiners so it would fit into his cold air box he made with pod filter
i think the pipe and filter cost $190.00 at auto shop (not the best pod filter ive seen just a cheapie) but he had a good filter already
he had to get a pipe welded on it for the hose wich goes to the intake manifold collector cost $15.00 3x silicone conectors about $10 or $15 dollars each
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
