if its got less than 100,000k on the clock have a look at the moto to see if its got a 100,000k service sticker, if its got the sticker pretty much means the clock been put back, for alot of r32,r33 gtst this is the case, i went to one import shop and they had 4 r33 that were like this, one had a 190,000k service sticker on it and the clock said 85,000. :cool:
Hey, im looking at purchacing a skyline and wanted to know what are some common problems to look out for and whats the best workshop to get a car looked at before i buy it? Thanks for your help
Hi Nick,
Certain idiosyncrasies exist (besides being vigilant for rust, any damage that hasn't been repaired properly, service history etc) whether it's an R32, R33 or R34. Which one?
To better answer your 2nd Q, just wondering what city u r in? Your Profile says 'Location Unknown'.
Regards, T
Hi Nick,
Regards, T
im looking at a r33 gtst and im in perth.
the post previously said about a sticker saying th kms just wondering where that sticker is usually put? its not the service sticker is it?
Hi Nick,
I believe that Quinny is cautioning you about a sticker on the block or thereabouts that would confirm that the timing belt has been changed &/or other things.
The previous owner if in Oz should have the Kms travelled according to the odometer at the rego inspection certicate to act as a progress marker.
Wear and tear on the bolsters and carpet + sun damage to the steering wheel are also markers.
If the car has been in Japan all this time, extra care has to be taken looking for rust in the undercarriage as well as hinges, body panels, around window seals because Japan has acid rain in Honshu as well as parts of Kyushu Islands combined with salt. But even in Perth, if you live anywhere near the sea, you'll get salt from the Fremantle Dr. Rust on Skylines ain't as bad as Alfas before the 90s but your investment is worth checking over. Look at the owner's body language as you ask him if he'll let you put the car up on a hoist.
On inspection, take >1 mechanic with you (to go through your pre-planned checklist) as you check for rust, oil leaks/seepage, sludge under/around the oil-fill opening, previous damage & bad repairs, air cond, electric windows, heater, windscreen chips, unevenly worn tyres, lights. If you detect damage, ask for his insurance company on that car so that a check can be done (on claims) with his permission. Also check for scratched paint on the corners of panel bolts around the engine.
Personally, I can't think of many things to specifically look for on a R33 GTsT, but hey, you'll pick up 100s of messages through the seat and steering wheel after you then start the engine.
Happy Searching!
T
JEVIC!
Check this link out, be better if more imports had this inspection, save alot of head aches for people before they lay there hard earned cash out on the table.
I have all my car inspected before they leave Japan.
http://www.jevic.co.jp/jevic_english/inspe...ces/index4.html
Edited by OzCarImports
Yup thats it when the timing belt was change
will the sticker have something written on it to indicate its been changed? or have to have something to be marked off? cos mine has it, but my odo is only at 88xxxkms
yup! could it be my belts were changed before the 100,000k service, or has my odo been wound back...
I was under the impression the sticker was there to remind you to get the timing belt changed at 100k and then when its done its ither replaced with a new sticker or they write on the existing sticker what kms the belt was changed. Wheres the best workshop to get the car checked? And roughly how much is it?
Just as Quinny above has said, it looks as if the odo has been wound back if
i) the sticker says that the timing belt has been changed already and
ii) you're the 1st Australian owner or
But then again, perhaps the oil pump's been changed!
It's recommended to change the timing belt if the oil pump has had it.
But if you're the >2nd Aussie owner, it may be that the previous owner changed it anyway through caution or the oil pump's been changed
The 100,000.00 service would be a KM or date service correct? Like most cars its whatever comes first. I know my GFs civic has had one of its major services (i think 50k service) and its barely cracked 30. Just the way it goes if you wanna keep your warranty
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
