hey guys,
after a genuine R32 gtr front bar with the lip
the 2 piece one not a one piece copy!
doesnt matter about paint but the lower lip cant be snapped in half or anything,
have cash waiting,
cheers,
Kyle
Edited by HI2U
https://www.sau.com.au/forums/topic/231021-genuine-gtr-front-bar/
  • 1 month later...
still looking guys
I have a genuine n1 with lower lip. Has a crack and a bit of damage (not to the lip but the actual bar), but nothing unrepairable. Have been quoted 100-120 by a plastic welder to fix. Bottom Lip is perfect but the whole thing would need painting.
I am chasing 250ish, or swap for a front bar for a GTST like a copy GTR. Let me no if ur keen, I started sanding it back but haven't really got the time to finish it.
PM me.
Edited by LRyder
  • 5 weeks later...
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
  • 4 months later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
