Make: Nissan
Model: Skyline R33 GTS-T
Milage: 110,000kms
Transmission: 5-speed manual
Colour: Black
Complied? 10/2003
RWC supplied? N/A
Currently registered? 4 mths NSW rego (till 11/2008)
Price: $14,000 ono
Contact: 0431390283
Comments / Modifications:
RB25DET 2500cc 6-cylinder RWD turbo engine
5-speed manual gearbox
Power windows / mirrors
Power steering
Power aerial
Air conditioning
HICAS 4-wheel steering
4-wheel disc brakes with 4-piston front calipers
Engine / Driveline:
3" mandrel-bent exhaust with hi-flow cat & chrome cannon muffler (5" outlet)
Hi-flowed turbo
Apexi Power FC computer with handset
Apexi Air pod with clear air box enclosure (legal)
Blitz front-mount intercooler
Turbosmart EBoost 2 electronic boost controller (set to std & 10-11psi)
Sard fuel pressure regulator
Sard fuel injectors
Twin plate clutch
Greddy blow off valve
New front EBC 'Green Stuff' performance brake pads
Blitz FATT-X Fully Automatic Turbo Timer
Nismo reinforced clutch pedal box
Pedders sport suspension
New clutch master & slave cylinders
New battery
Exterior:
18" x 8" XHP chrome rims (with 235/40/R18 front & 265/35/R18 rear tyres)
Veilside rear bar, rear spoiler & side skirts
Custom front bar with clear indicators
Eye lids
Blue/white LED park lights
Interior:
Custom silver dash with silver gear knob & handbrake
Autechnica black & silver sports steering wheel
Genuine Nissan Skyline R34 floor mats
EL display instrument cluster (adjustable green / blue)
Fully motorised TFT monitor with TV tuner (w/ amplified 4-way diversity antenna)
JVC KD-DV7305 DVD / CD / MP3 / WMA / USB / DivX tuner with remote
Kenwood 7" x 10" 3-way rear speakers
Power Acoustik 4-channel 600w amplifier (4x75w RMS)
Images:
Feel free to contact me for more information or pics. Inspections welcome.
Edited by Marcos
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
