Hello
I just thought i'd simplify arrangments for this mini meet (*if it happens) on Satuday by making a new thread.
Basically, we're planning to at Glen Waverley Train station carpark (Happy Cup) for those who live out this way.
Then head into the city and meet up with others at Albert Park (where exactly i'm not sure, but hopefully someone should post the precise location...).
I'm well aware of the cruise going on later that night, therefor we'll say 3PM at Glen Waverley, and 4PM at Albert Park.
I know it's a bit late to post this, but hopefully the word spreads well enough.
Check this post Saturday sometime just to confirm.
Any Probs.... my number is 0413 934 330
See You Saturday....
:burnout:
https://www.sau.com.au/forums/topic/23197-mini-r32-meet-saturday/
Just a suggestion for future reference:
When you're organising events, a date is always a good way of getting people to turn up.
'Saturday' is a bit too general, as most months have 4 Saturdays, you're kind of leaving it up to the reader to decide which 'Saturday' you're refering to.
:D
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
