Item: trust/greddy 13 row oil cooler & relocator kit
Age: brand new
Condition: in original packaging, only opened box for inspection
Price: $1000 + delivery at your expense if needed
To Fit: R32 GTR
Contact: pm
Comments: dont really need this as im not planning on doing any excessive track work, im also interested in swapping for a brand new trust/greddy oil filter relocator for r32 gtr so i can still plug in my gauges as planned.
cheers :domokun:
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
