Item:
1 x Defi 60mm Boost Gauge (2bar reading) - Stepping Motor Drive
1 x Defi Boost Sensor
1 x Defi Daisy Chain Loom (for other Defi Gauges
1 x Defi Instruction Manual
2 x Foam Strips
(all you need to buy is a 60mm cup, a holder, and the Control Unit)
170820088321200aj5.th.jpg 170820088291200av7.th.jpg 170820088311200nl5.th.jpg
Unknown, but it is 2nd hand (un-used on my part) - as far as I'm aware, these are not available anymore!
Condition:
As new condition... wires are still all wrapped up from the box.
Price:
$150 + delivery / pickup
To Fit: (What car)
Any car really, but you will have to purchase the Defi Control Unit (around $80?)
Sydney Northern Beaches
Contact:
PM Preferred
Comments:
Reason for sale, only ended up using Oil Temp n Oil Pressure
This is the real deal, not some fake imitation crap... Defi are amongst the best in the market so make sure you don't miss out on this opportunity to snap up a nice unit at a low price.
FYI this gauge is not like the usual Defi items you see on Nengun with the black face, this gauge is visible from square one. It reads in kgf/cm2 and has a "warning light" and "peak" indicator. As with all Defi gauges, replay is available through the control unit.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
