Make: Nissan
Model: Skyline R34 GT-t
Milage: 78,000
Transmission: Manual
Colour: Silver
Complied? Yes
RWC supplied? Yes
Currently registered? Dec 08
Price: $24,500 ono
Contact: Daniel 0423 089 477
Comments / Modifications:
10psi boost
HKS Coilovers
HKS 3" Cat Back Exhaust
19"x8.5" Osaka RS5 Racing Rims (235x35 front 245x35 rear)
Apexi pod filter
Bendix Ultimate Brake Pads
5spd Maunal
ALSO COMES WITH NAVMAN S30
ALL STANDARD PARTS ARE SUPPLIED ALSO (RIMS, AIRBOX, EXHAUST, SUSPENSION)
-Full Custom Stereo-
2 x 12" MTX Thunder subs, custom box with false floor and hidden compartments
MTX Mono Block amp
Pioneer Headunit
Pioneer 6" speaker in doors and rear parcel shelf
TRADES ARE WELCOME BUT IM CHASING ULTIMATLY A NISSAN NAVARA OR TOYOTA HILUX. 4X4 TURBO DIESEL.
Images: coming soon having trouble uploading. i can email for those interested
Edited by cheez
https://www.sau.com.au/forums/topic/232641-1999-r34-gt-t-skyline/
forgot to add somethings in that i missed.
greddy turbo timer
razo gear knob
nismo bodykit (plastic)
open to offers guys but its a good price almost considering how she looks.
what!!! why sellin it for bro? Its too nice of car.
But i have seen this car. drives extremely well, and is in immaculate condition.
Good luck on whatever you decide to do mate :action-smiley-069:
im selling coz i just want to get out of the sports car thing and start focusing on more of my love for shooting and 4wd, thanks for kind remarks.
also its got VIPER alarm.
bump
hey bro how long has your skyline been up for sale because i think its the time of the year or something coz i havnt had any intrest or nothin
only a few weeks, had some interest but nothing solid yet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
