  • Replies 230
ok guys/girls i will can this as well if people cant give aanswer and a serious one by the middle of december as i wont have a repeat of this years dont forget vili's friday night i think i said 7pm
it is a cruise to melbourne this is why i organised it, we drive to meet up with the sau boys have a cruise drive back to the hotel ect what are you going to do while we are cruising and your on a plane
Friday:
we arrive at aprox 3pm to hotel
we go wash cars
we go have dinner
we go meet the Vic SAU boys
we go on a cruise the meet spot is aprox 1 hour away from our meet up with the Vic boys
we go back to hotel
Saturday:
we go to Luna Park for a few hours
we go to Torquay for lunch and shopping
we go to Lygon Street for dinner then the Crown to drink and party
Sunday
we go to Chapel Street for lunch and shopping
we go meet up with Vic boys for dinner
we go out for photos
we go back to hotel and drink in one of the rooms
Monday
we pack up hotel
we go out for lunch at Melbourne markets
we head home at 2pm
thats the plan
tiger airways fly to tullamarine, tullamarine to St Kilda is about half hour, depending on traffic. thats what google maps tells me anyway.
Edited by Damo_R34
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
