Hey all ,
My name is Mitch , long time lurker but seeing as im picking up a 33 on friday i thought i may as well become active in the forum !
after driving a VT commodore for the last few months ive decided to get rid of it and get something i can spend money on and see results.
anyways im picking up an R33 GTS4 on Friday (22/08/08) and i plan on taking it for a good drive to get used to the 5 speed as opposed to my commodores 4speed auto that ive become used to.
just wondering if anyone is gonna be out cruising and if so , would like to meet up or something so i can slowly meet the Adelaide members and come out on sweet cruises
just reply to the thread if your interested ,
cheers
Mitch
https://www.sau.com.au/forums/topic/232779-an-intro/
  • Replies 51
Congrats mate...imma lurker too..cant afford a skyline for the life of me lol.
But look forward to seeing ya out and about. Come charlies on friday lol :P
haha yeah im trying , literally all of my savings have gone towards this car and ill no doubt be flat broke !
time to beg the parents for some cash i think haha , look forward to meeting all of you :P
https://www.sau.com.au/forums/topic/232779-an-intro/#findComment-4082636
But look forward to seeing ya out and about. Come charlies on friday lol ;)
*cough*bollocks* could prolly get you into an import for dirt cheap buy local and you pay more than if you import with a wink and a nudge
sure are ,
couldn't be bothered resizing :P
bad luck to my 56k friends i suppose :P
nice Welcome aboard Lurker ;) has it been converted to a turbo
i think some of us are meeting @ Villies on friday night probably around 7pm hopefully i can sort my heater core out
https://www.sau.com.au/forums/topic/232779-an-intro/#findComment-4082705
and some of us are going to the ramsgate, haha.
Looks mice Mitch, I'd change the rims personally, but im sure that's on your long list of modifications :)
mate , the rims are the utmost FIRST THING GOING OFF THE CAR
i cant stand the size and offset at all , makes it look like a go cart at the front :thumbsup:
That's just begging for a DEt conversion - baby GTR! (hey Steve) :)
thats what its getting after new wheels and tint
with an rb30 bottom end of course :bunny:
https://www.sau.com.au/forums/topic/232779-an-intro/#findComment-4083211
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
