hi guys,
ive taken my r32 gtr to the track a few times & have now developed a whine noise in the rear diff - i did a search & it seems that those big launches may have caused this.
this is when i hear the diff whine noise:
- between 60km/h & 100km/h, anything above this speed & the noise is no longer heard
- when the diff is under any type of load i.e. accelerating & decelerating
funny thing is if im cruising at this speed where i hear the diff noise & i very lightly accelerate where the diff is not under load or deceleration (kinda like a balancing point for lack of a better explanation), the diff is completely quiet...
any ideas? i think its diff related & not a wheel bearing
https://www.sau.com.au/forums/topic/232966-rear-diff-whine-after-14-mile/
Sounds like the bearings in the diff have let go. For the price of new bearings you might aswell get an aftermarket lsd that comes with new bearings and seals etc.
what diff centre would you recommend?
would redline diff oil help with the noise as i know it helps with syncro's in the gearbox
You have snapped all the tags off the drive plates in the clutch packs...no biggie. Get it rebuilt by Terry at Award Diff and Gearbox at Rydalmere for around $500. He will modify it as well as fit the stronger Nismo clutch pack set...you wont break it then.
I use a Kazz 2-way, got it for $900, but i use it for drifting. Came with new bearings seals etc.
Redline oil helped the syncro's in my gearbox as well. But if it is the bearings in the diff, because the amount of pre-load they have, once there gone there gone.
I would suggest to get an aftermarket lsd, but i would also suggest listening to DiRTgarage as i would say he knows his stuff when it comes to dragging gtr's.
Edited by White GTS-T
R32 GTR diff's are a 2 way mech item from factory...with the "Terry mods" and the clutch pack would be as good as any aftermarket item. Its all i use...they work!
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
