Hi, I have had some sveatty days working out with the rb25 gearbox. First time the two plates were not aligned so I couldn't even get the gearbox in and had to take it out again. This time the box went all the way in but now I can't get any gears in when the engine is on. I tried bleeding the fluids and adjusted the pedal as much as it goes. Then I lifted the rear up and started with a gear on, then the wheels spinned even with the pedal down. When I pushed the break and cluthc the rews went down a bit but the engine didn't stop. Could it be that I put one plate the wrong way? That could show some slipping, like what I have? Now the plates are not the same way. The plate closer the engine has the "outcoming" part in the middle facing the engine, and the plate closer the gearbox is the other way. Does anybody remember how they should be. Or is there maybe something else you could easily mess up in the installation since this was my first time :) . All I have is japanese instructions wich didn't help so much. Thanks.
https://www.sau.com.au/forums/topic/233019-orc-709/
Did you use the right bearing carrier? Have to decipher the instructions to figure out which one is right for you.
Sorry my english for the parts names isn't so good, but bearing carrier? I think it's the new part we changed with the bearing that I ordered with the clutch set from rhd japan. It is the part you attach to the bearing between the clutch and gearbox? It has the same effect you're right. I can send the japanese instructions if someone understands them. Yeah, by the way it is a dampered clutch if it has any difference. What is the right bearing carrier, have to check it out when I remove the gearbox... again.
https://www.sau.com.au/forums/topic/233019-orc-709/#findComment-4087305
By the sounds of it, I would have to agree with BNR#@.
It sounds like your bearing carrier is too short for your application, so that even at full throw the clutch isn't being disengaged.
Even though the manual is in japanese it isn't really hard to work out which one you need for your car.. numbers and pics make it easier to follow.
By the way, Thanks to Serg for helping out gavin at cypher with my clutch. Thanks heaps mate. I think they were under the impression that I didn't have the manual. Hopefully it is the nastiest clutch install that they have to deal with for a long time as it needed a pile of other bits replaced and a real bastard to fit it all back in.
Clutch bites like a bitch, but seems to be getting a bit nicer after a couple of days use. Zacka tuned it on thursday night and it made 350.6 rwhp @ ~17psi. All via hand controller too. Very happy.. for now.
https://www.sau.com.au/forums/topic/233019-orc-709/#findComment-4087847
post-43975-1219666533_thumb.jpgOkay, according to the picture the distance between the lines in the bearing carrier should be 14-16mm, agreed? I'll take the box out tomorrow and measure it. I just thought that the pieces would be right because they came in the same package, well you learn from your mistakes.... :D
https://www.sau.com.au/forums/topic/233019-orc-709/#findComment-4090939
Haha, I was actualy there helping them lift the gearbox when they were trying to get it in with your front pipes still attached, not fun, bloody heavy bugger to... No matter how the box was angled it wasnt going in... The clutch does bite but you realy get use to it fairly fast, yours rattle to?
https://www.sau.com.au/forums/topic/233019-orc-709/#findComment-4093061
Rattle? hmm.. put it this way, my wife reckons that my car came back broken. :D
Bit of a zing when starting, and bit of a clunk when coming in to a stop with the clutch in like a uni-joint type of noise. Pedal effort is almost half of what the original one was, a heavy duty single I am led to believe.
Gavin found out how much fun it was to try and refit the front pipe to those dump pipes as well, it took me about 3 hours to do it myself on the shed floor the first time..
https://www.sau.com.au/forums/topic/233019-orc-709/#findComment-4093166
Haha, get use to explaining to everyone that it rattles because its so hardcore :)
Mine has a nismo slave cylinder so is light as a feather, would have actualy prefered it a bit heavy er but use to it now...
Was there when he was taking your fronts off, was gone by the time he was puting them back on, figured wasnt gona hang arround for the second round of lifting that box :(
https://www.sau.com.au/forums/topic/233019-orc-709/#findComment-4093315
My friend had a similar problem, he found out that the tube which carries the bearing carrier pressed the clutch plate all the time. And that didn't allow it to release, he had to cut about 1cm of the tube away to get it to work. Have to check today if there is any signs of contact. The bearing carrier had the lenght that was adviced in the instructions, but still there is about 1,5cm loose in the fork movement before it started to push the clutch (before it got stiff). Is that okay?
https://www.sau.com.au/forums/topic/233019-orc-709/#findComment-4096781
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
