Item:Work VS-KF 18" +26 offset allround
Age:Unknown
Condition:Good
Price:E.O.I.
To Fit: Nissans with wide gaurds and gtr's i think
Contact:Fran: 0402773212
Comments: I bought these wheels to hopefully go on my car but they do not fit. I haven't driven on them once and when i bought them the guy said they have 80% tread left. The wheels will come with JJR spacers F-15mm R-20mm. Im looking for expressions of interest, and i know i wont get back what i paid for them but there just sitting in the garage doing nothing while someone else could be enjoying my mistake. Any reasonable wont be refused, but no silly buggers.
Sorry i have no photo's as i dont have a digital camera, but im sure if you type in VS-KF in the search it will come up with a picture.
Thanks heaps guys.
https://www.sau.com.au/forums/topic/233020-eoi-work-vs-kf-18/
Hi what width are the wheels and what colour are they also and is their any markings/stratches or dents on them at all?
fronts are 225 so 8's and rears are 235 so 9's. they are chrome with a minor scratch i think off the top of my head but i'll get back to you. ive gotten hold of a camera so i'll try and get pictures up tommorrow for you.
18 x 8/9 +26 should fit,
whats the problem?
need the spacers to clear front brakes making them stick out bout a centimetre, so they would be perfect for ppl running wide gaurds. or who can be bothered getting gaurds pumped a bit.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
