Originally posted by Steve
Emissions test are a bloody joke anyway.  If a car is not passing an emissions test, one of the ways to fix the problem is to inject air into the cat - holden have been doing it for years, pretty sure nissan did it too on SR20s.
Are you sure it's air and not methane gas from the driver's seat :)
Found out some interesting news about emissions testing. Aparrently this place that does the $350 test isnt being accepted by regency, but they are still trying to fight that one.
BUT, they will accept emissions tests done by NSW govt, or at mitsubishi. Who cares? I have been told that it is free in NSW vs $3k at mitsubishi, just got to book your car in???? Would be interesting to see how hard it would be to get in, cos if it costs $3k here, NSW suddenly looks like a fantastic place to take a holiday.
Will have to investigate further....
There is a guy in adelaide who can do an emissions test on a dyno, but the accuracy is not high enough for the RTA. To get the accuracy they require involves mitsubishi and $3k.
I was also told that the NSW govt provides free emissions testing, that is accepted in SA. Wonder how hard it would be to get that done? Even if you have to grease the wheels a bit, it would be alot cheaper than going to mitsubishi.
Found out some info on emissions testing
http://www.rta.nsw.gov.au/environment/airq...lemissions.html
There is a free call number to book the vehicle in, and it meets australian standards, free test and takes up to 1/2 hour.
I checked with the guys from regency, and they will pass a car with a larger EDIT turbo if it has an emissions report - probably why you are in your situation 9krpm?
I think I will have to check to see if they accept NSW engineering reports too:)
do you need an engineers report for the mods + an emission test? or just the emission test?
can you recommend an engineer? A friend of mine recommended 'BC Tonkin & Associates'... apparently they are on the Transport SA list of recommended engineers. D. Potts (australian Technology PTY LTD) is on the list as well... is he dodgy or is it just the emission test he does is that is unacceptible?
I've been told all I need is an emission test.
Then I was told to get an engineering report after the emsission test and bring the car for Regency to check. This is like another $70 down the drain after
-?$3K for emssion check
-??$$$ for engineering report
Why does Regency need an engineering report? Couldn't they check/assess the safety them self? If they can't then why do they need to check the car after an expert made a report/safety check aldready?
Toooooooo many loop hole for the government to make money!!!!! STOP IT I DON'T LIKE IT :(
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
