t3 turbo off a vl with t4 internals dump pipe and actuator and lines little shaft play will make 250rwk $400 ono
gtsx interia seats front back door trims and side trims $400 immac cond
rebuilt rb20 r32 gearbox all been strengthnd and new sincromes never been used ever since rebuild basically better than new can handle 350rwk $1200 cheap plus month waranty
gts-r plenum top half brand new for rb20 $200
custom rb25 top half plenum with standard thb $120
stock rb25 cooler and top half plenum $50
xf throtl boddy $50 new
coupe boot lid $100 good cond
or pay $2000 and get a great deal,rebuilt rb20 r32 gearbox gtsx whole interia hi flow turbo and rb25 custom plenum with throttle body,with one month money back if anything happens to gearbox GREAT BARGAIN.
DONT HAVE TIME TO SEND PIKS ON COMPUTER SO SEND ME UR MOBILE NUMBER AND ILL SEND PIKS THREW PHONE INSPECTIONS MORE THAN WELCOME,O402353698 CHEERS
