  • 4 weeks later...
  • 3 months later...
Popomano, the website you posted is urs?
cos if it is, I dont know if you realise that it is actually illegal to sell, use and have a radar detector in Victoria. I should know because I also used to do what you do. Which is order stuff cheap from the states online, and resell it down here. People if your interested getting the 850MP, just order it from the states for much less. If you want a good reputable dealer, I still have my contacts and can pass you on the details.
  • 3 weeks later...
tell me about it....I've got..
- gts4 telling me its worth only $200 ....even though they were advertised at JB's at the time for $900+.
- NickySantoro giving me lectures on radar detectors
Anyway...Nickysantoro-I'll be interested in some US car audio sites though, can u pls inform all of us on some sites.
I know fastcar.com.au are prtetty good, I've purchased 2 units from them and they took off almost 100 off there alrweady cheap prices. I didn't like the Sony..so i went for the top of the range Kenwood unit on there site - i'm reallyy happy with this one.
Your a clown man ill give you $200 for being dumb
man you guys are the biggest retards..
no offnese, if you guys can really think you can get this machine for 200? 300?
I GIVE you 200-300 dollars and you go buy it for me. IF you can, take the machine...
IF this is really BRAND NEW then 650 is a VERY good price. If it is 2nd hand den yes 200-300 is the price..but if this guys really means it that it is new...den it is worth the 650
I got mine for so cheap considering its over in asia which is TAx free + the strong Australian dollar.
  • 3 weeks later...
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
