Hi guys,,
I've got RB25Neo turbo with RB20 actuator, since i've got that done my car run on 14psi without any boost cont. Then, i've just got EBC installed today (profec b specII) and tried to get the boost down to 10psi on low boost setting,, could not do it even i set everything to 0 setting, car still ran 14psi ...
anyone know what cause this issue? and how can i lower my low boost setting?
Cheers
https://www.sau.com.au/forums/topic/233624-boost-wont-go-lower-than-14psi/
The EBC wont lower boost, you cannot lower boost any further than the actuator... which my guess is either a 14psi one...
or its a bit bent giving you 14psi base.
If those two arent it, maybe the dump is hitting the wastegate flapper not allowing it to fully open
Thats really the only two things that come to mind
yeah ive been running 15psi on stock turbo for a couple years now, still barely any shaft play, not bad at all, drift everyweek aswell so it doesnt get an easy life, it will be sweet, run 14psi as low boost and then 18psi as high boost lol
Actuator... If you set it to 0 it runs on the actuator so its been moddified or you have an aftermarket actuator.
14psi is ok wont last forever though. If you dont drive like a nut dont be to worried.
no, it's not an aftermarket actuator for sure
same here, run 14psi as low boost and 17psi as high boost,, but never run on high boost tho lol
Cheers
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
