Mitsubishi Evo 9 front brake callipers
DBA 5000 series slotted rotors 330mm diameter ( my be 340's ill have to check)
Custom made race brakes Alloy hats
90% Ferodo DS2500 brake pads
Custom made adaptors to bolt to R32 GTR hubs ( or anything thats the same)
The callipers were removed from an evo and I bought them to use on my GTR. Had the rotors done and adaptors made up.
Rotors have done about 5-6 meetings, the hats have done more but are in perfect condition, they also have two sets of rotos mounting holes, one set suit off the shelf HSV rotors and the others suit endless rotors that I used as well ( may throw them in as well)
Callipers have some paint damage from rushed brake bleeding and split fluid but other wise they are fine condition
Pads were replaced and have done one practice day. I can also supply other various brands of pads to use with them.
The adaptors are designed for an R32 GTR or anything else with the same bolt spacings. They are steel and seem to work fine.
Due to the near new rotors and pads I want $2000 ono for them, which I think is reasonable considering the cost of R33 GTR brembos.
Located in sydney and inspections welcome/ prefered before purchase.
Edited by Risking
https://www.sau.com.au/forums/topic/233991-evolution-9-callipersrotors/
Hi ,
Why are you selling these ,did the conversion not work well ? i only ask because i am in the middle of doing something very simular with front and rear evo 8 brembos. I was hoping to go out to 360 mm front discs.
Who made the adaptor plates for you?
Hi ,
Pm sent
Edited by Risking
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
