Item: RB25DET front facing plenum
Age: 6 months (top section is 6 months old, runners I wouldn't have a clue)
Condition: As new
Price: $550 ono
To Fit: R33 RB25DET
Contact: PM here or email [email protected]
Comments: Had this plenum made up for a customer but he changed his mind and project has taken a different route this unit been flow tested will get results asap
https://www.sau.com.au/forums/topic/234133-rb25det-front-facing-plenum/
i could be mistaken Anf but is that osheen's motor im lookin at in these pics???? lolz and how long until that puppy is up and running again???? also if i get this plenum i have a 90mm TB off a Q45 will that fit on it or not??? just curious
spot on dude
just waiting on a new T/B and other bits, wiring is just about finished
once the parts arrive a bit of fabrication and its all done
you would have to get a new flange welded on it to use a Q45 T/B
lolz any chance of a mates rates price???? :( little strapped for cash atm and i gotta get pretty much my entire engine bay engineered....... and thats gonna cost me an arm and a leg..... any ideas on where i could get an engineers cert??? and i need to get a plumb back setup for my new turbo as my BOV is venting to atmo and i need engineers cert for the non stock turbo, fmic and pod filter i need to get them all engineered..... any suggestions?
  • 2 months later...
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
