Here's some feedback, Ben.
IT'S ABOUT TIME!!! ;)
Awesome that the site's up. Best of luck with it. If that's the cover of issue 35, then what the hell did i just buy from the newsagent with the two Kansai Supra's on the cover?!?! Don't tell me I bought an issue I already own?!? Wouldn't be the first time though. D'oh!
(EDIT: oh... never mind).
In any case, keep up the great work and keep the dvd's coming too. Must have more!!!
Adrian
https://www.sau.com.au/forums/topic/23430-hpi-online/#findComment-501666
