Wrecking R32 Drift Car And Rb26 Parts! Twin Td05 Kit, Td06 L2 Kit, 5 Stud Conv, Cage, Bodykit, Panels, Radiators, Intercoolers And More!
I'll take the Cusco radiator if it suits an R32 GTR without modifications.
I'm in Adelaide too so no need to freight it to me; I'll pickup.
  • Replies 64
all those bits to get rid of or you will be cramped for space? haha thats unlucky as you can come get the 5 stud rear n other bits i have for ya :)
Very Interested in the cage! But I'd like pic of the whole thing and/or you made it?
Rhys
Its a Jap one but the brand wasn't listed. Here are the only other pics I have showing the front bars of the cage.
all those bits to get rid of or you will be cramped for space? haha thats unlucky as you can come get the 5 stud rear n other bits i have for ya :happy:
Haha finally off the car? I'll have to pack some lunch for the drive.
question about the trust cooler. is it for a rb20 origionally or is it for a r32gtr origionally?
The Trust cooler pictured is off a Silvia with an RB26 transplate, twin TD05s and was set up as a drag car in Japan. Had a line locker, no front swaybar etc.
I would say it is for a GTR as it is 150mm thick which is complete overkill for any RB20 setup. As far as I know its the thickest Trust make.
could you please pm me some more detailed specs on the td06 suit rb25
also wat size rear housing is it?
Are the tail lights still available? depending on price and if they will fit my 32 4 door ill take them.
unless you change the rear beaver panel (where the tailights bolt onto) then you cant use r32 coupe lights
leave them as sedan lights they suit the car better and thats what makes it a 4 door to :P
leave them as sedan lights they suit the car better and thats what makes it a 4 door to ;)
I just don't like how they are black. would rather it all white bar the parts that light up.
Might just have to cover everything up and spray them.
Deposit/full payment taken on
Bodykit
Injectors
RB20 head, cams, cam gears, head gasket
Coilovers
  • 4 weeks later...
I've PM'd as well, wanting to find out when I can pick up the radiator.
Some communication would be appreciated.
Ok its been a month since anything has happened, i dont really want to start making any accusations but im starting to think this may be a scam.
Prove me wrong
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
