The following parts might shock some of you, but they are for real 800+hp setup, due to finacial problem, my project for twin-turboed G35 is not gonna work out....so i offer those who are really interested into performance this chance... BE QUICK before they are gone
They are all brand new and still sealed in the box, i'll post some photos for some parts that can be opened easily to take photos, the rest will not be taken until someone is really into the deal, if u are in Brisbane area, i can meet you and discuss about it...
CP pistons (VQ35 20thou oversized; 8.5:1 compression ratio)
EAGLE H-beam rods
KOYO 36mm radiator
VQ35 ARP Main Stud Kit
VQ35 ARP L19 Extreme Duty Head Studs kit
Cosworth Stopper Ring Headgasket VQ35 96mm .6mm (good combination with the pistons)
JWT C2 Camshaft Set VQ35 (for forced induction)
JWT VQ35DE Valve Spring & Shim Kit
Cosworth Nissan VQ35 (3.5L) Main Bearing Set-Tri Metal (standard size, but gives stronger strength)
Cosworth Nissan VQ35 (3.5L) Rod Bearing Set-Tri Metal (standard size, but gives stronger strength)
Cosworth Nissan VQ35 Thrust Bearings Metal (standard size, but gives stronger strength)
Unorthodox Racing FullPulley Set (Crank, Alternator, and Water Pump with Belts)
JWT Lighten Flywheel and Clutch Set (for forced induction)
D2 coilover for 350Z/ G35
Project Mu brake pads (for Brembos)
Please consider the above parts are new, i spend more than USD$8000 plus shipping, now i only want AUD$8000 for them....
It is a real great deal, only once in a lifetime
please PM me for more details you would like to know
https://www.sau.com.au/forums/topic/235154-fs-800hp-internals-for-vq35/
The problem is that few of the Aus 350Z owners have twin turbos to justify a bottom end upgrade.
I only know of a half a dozen in Sydney, and all but one of them have rebuilt bottom ends already. The last one is upgrading handling/stopping/drivetrain right now.
There's a dude in Melbourne (ZTRACK, who helped APS develop their TT kit) who runs a stock engine. I'm not sure if his finances will cover this, though.
  • 3 weeks later...
  • 3 weeks later...
    • Need to see other side of PCB in that area...ie; I don't see any thru-hole mounting, just soldered vias (smd zeners in SOT23 have 3 legs but only 2 are used, as reflected by PCB tracks)
    • 4 to 5 is fine. It will be slow, but that's better than blowing turbos. I don't have a PS pump idle up solenoid on my car, because... I think when we put the Neo in we retained my R32 lines. But.... From inspecton of the R34 vacuum hose diagram, you can see that the solenoid needs to be connected to the turbo inlet as source of clean air) and the plenum (as source of vacuum - which is the place for the air to flow to to cause the idle to increase). So 3 to 1 is VERY WRONG. 3 should go to either the turbo inlet, or the plenum. Follow the other hose from the PS solenoid and if it goes to the plenum, then your 3 goes to 2 2 would also serve as a bleed port for a boost solenoid.
    • Pull them out and pull more apart. You can't do shit with them still bolted to the floor of the car.
    • Yes it is. ZD1 is on the other side of the board. Where ZD1 is marked is clearly opposite a 2 pin device. Our 3 pin device here is not a ZD.
    • Alright, a little update on this... I called Fulcrum, who used to be the distributor in Australia. No Bueno, they don't service them anymore.  Called shock works, who don't service them but offered to dyno the shocks for performance, and suggested DNA in Sydney might service them.  Called DNA, who also do not service them and basically said they try to steer customers away from tein for this exact reason these days- there is just no support for them anymore apparently.  Both SW and DNA said they are a not necessarily a bad product, but they just don't service the brand or know anyone who does service the brand anymore.  So... I could keep calling around but at this point I think I'll probably just spring for the shockworks product, unless anyone here knows anything.  Cheers 🍻
