Item: 94mm 'Trust TR Drag' or 'Power Evolution II' cat back exhaust
Age: 1 Year old, but car was off the road for 10 of those months.
Condition: As good as a second hand exhaust will get. There is a slight graze on the underside of the rear cannon, but that could probably be polished out. See photos.
Price: $850
To Fit: R32 gtst. Im positive it will fit on an R32 gtr as well.
Location: Central Coast, NSW. (Gosford - 1 hour north of Sydney)
Contact: Shaun
I bought this exhaust for $1150 from Nengun about a year ago for use on my R32 gtst with Rb26 in it. I sourced the Trust drag exhaust because i was after something without restriction and that was as straight as possible. This exhaust flowed over 350rwkw and sounds great.
Its got a center hot dog style muffler and rear cannon, both straight through perforated tube design. The rear cannon is highly polished and machine tig welded stainless with a 115mm tip, while the tube is 94mm ceramic coated mild steel.
The exhaust comes with a silencer that can be placed in the rear muffler and is undetectable by authorities. I used this silencer for both my engineers certificate and RTA inspection (while re registering my car with significant modifications), and no one took a second look at the exhaust.
Without the silencer, and with my 1.06ar turbine housing, the exhaust was a bit loud for my purpose. My mates didnt have a problem with it, but im a bit conservative.
Note that this exhaust probably will not be a bolt on excercise, and will require simple modification of your front pipe. Nothing that a normal off the shelf exhaust will not require though.
This exhaust is no longer available anywhere in the world. There is one last place in Australia that has some for R33 and R34, but none for the R32. Im fastideous about my car, and this is a beautiful quality exhaust. I'd keep it if my diff didnt let go.
Please dont hesitate to contact me for further enquiries,
Shaun
0414 972596.
Edited by Shaun
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
