Item: Recaro Style Red/Balck Racing Seats
Age: Drivers seat has been in car for about 3 months and passenger seat has never been fitted
Condition: very good condition with no rips or tears
Price: $350 plus postage
To Fit: FD RX7
Contact: Jaron on 0417 059 540
Comments: Same seats as in pic below, please note pic is not of actuall item
Cheers
Jaron
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
