ive had 2 emanages tuned. both tuners had never touched an emanage before and one was very skeptical. both loved it and praised it afterwards as it is very user friendly
bottom line; you dont need a special 'emanage tuner', just a good tuner who knows how to use a computer... which should be all :thanks:
try pm-ing guilt-toy if you can do weekend tunes in newcastle
btw it can take a while to install, so DIY will save you a lot of dosh. i paid the extra $130ish for the plug n play harness, as it also includes the timing tuning ability whereas the basic harness does not.
Thanks for the advise, where did you perchase your plug and play harness? I'd love find one.
nengun.com ............. its like a 6 week wait or more from japan
i think autobarn sells emanage parts, but the RRP might be higher than direct from japan. give em a call
o also, with emanage you need the tuning cable that plugs into the emanage blue and the laptop. its a locked special gay emanage cable worth $150 or something lame. if you can find a tuner or a friend with this cable you can save that money too
now i feel like a tight arse telling you how to cut corners haha
Edited by InterCooL
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
