please explain why a hammer hit your nuts.
i was working on my lathe, knocking the job around to make it run true(700kg weight,approx.700mm long and 500 in diameter).
was standing on the lathe hitting it around and hammer slipped from my hand before i hit the job at full swing.
probly running from a penalty tap into 4-5 islanders in U/16's...man that hurt my head and my pride.lol
I went into hospital cause i had Miller Fischers Disease and the Nurologist chick Dr was giving me all this bad news,so i ask 'Will i walk away from this?' she goes 'Not from what i've seen' That was inside pain,man that sucked hard.
    • Definitely a good “future upgrade” option if you plan on keeping the car and dialing it in even further.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
