I think I may have the same problem.
The timing belt + a few others was changed about 7000 ks ago. It does only seem to happen when it's cold.
I do notice that the oil light is on while it squeels. The squeeling and oil light both stop/turn off at the same time. I thought it may be the oil but I changed it 2k k's ago and am using a full synthetic 5w-40 oil.
Water pump...... old falcon's and some smaller car's that make that sound.... it's usually the starter OR the water pump.
I dont know if skyline's have a water pump set up using the belt's.... or if it is independant....
but it's a thought
  • 10 months later...
  • 1 month later...
my car is haveing the same problem but i know its the starter and i will be greasing the shaft tomorow is it the starter motor shaft or the solenoid
it will be the driveshaft , take the starter out put it on the bench vice ( secure it on the vice ) then get a 12 volt battery put - on the vice or starter body and the +where the + ( thick cable) was when it was on the car . with a screwdriver touch the + pole with the solinoid then it should push the drive out and spin .
if the bush at the end hasn't got free play just grease it then spin it so the grease goes in it , dont put to much grease on it though as it will spew everywhere .
when you put it back it should be ok but dont be surpriced if after a few months it does it again .
check the ring gear teeth and the drive teeth for wear , damage as well .
starters on the gtst are easy to remove on the gtrs are a lot harder ( hard to get the top bolt )
Mine has started squealing as I have just had 100,000 kms service and all belts changed.
Never did it before. Yesterday it squealed both on acceleration and changing gears to take a corner. Very Loud. Slowed down and took it easy.
I noticed powdered rubber on the alternator. Tried some belt grip sray which has fixed it when accel - decel but not on startup for a second or two,.
Im a bit worried it may be my alternator packing up.. Belt feels quite tight. Could it be the alternator is getting harder for the belt to turn or something???
Glen
:Edit for typos:
if the belts are all tight then you may have problems , to check take the belts off one by one then you will find out what it is .
when the belt is out try to free spin the alt it should spin freely and no noise .
What About The Tensioner Pulley Bearings For The Cam Belt???
There Are A Lot Of Things That Can Make Squealing/squeaking Noises - A Lot Of Bearings On The Front Of A Skyline.... Water Pump, Air Con, Pwr Steering Pump, Alternator, Starter Motor, Cam Shaft Pulleys. Vvt Can Make A Bit Of A Noise As It Pumps-up Too If Left For A Week Or So.
Bit Of A Worry Really Especially If You're Not Really Mechanically Minded - A Lot Of People Change The Cam Belt But Overlook The Idlers. My R33's Weren't Much Chop After 80000k's.
A Snapped Timing Belt Wouldn't Make Your Day Very Nice.
ok i got the starter out and every thing looked really dry and black just carbon i guess i greased up the shaft and looked at the solenoid it to was dirty so i put some penitrating oil on it i used some aircraft quallity grease on the shaft hopefully it does the trick for longer than a couple of weeks but all works fine now thanks mate
  • Like 1
it should be ok , if you cleaned everything but dont be surprised if does it again on cold starts but not as bad as before .
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
