HKS sequential BOV on Hotpipe for R33 GTS-T - $150 Delivered /will fit straight onto R33 GTST or can salvage the adaptor from the pipe and weld onto any hotpipe or intercooler pipe on any turbocharged car provided piping is aluminium.
Stock R32 GTS-T RB20DET Manual transmission ECU - $150 Delivered[/size]
2 Pair-sets of foglights, one in pure brilliant white, and one in amber. Great working condition, almost regret getting an aftermarket front bar as I can no longer use these. They work fantastic (they'll take out an eye if you angle them up) - $80 a pair
2 x FET motorsports Strut Brace R32 Skyline will fit R32 GTR - $150 eachpickup ono these are fatter and more solid than cusco biatches
Perfect working order, could do with a wipe down... Fatter and more solid than cusco
S14 front seats, no rails - $200 ono pickup
Fantastic condition, no ciggie burns, rips, holes, tears, or stains
4 stud hubs - $50 ono pickup
4 stud conversion uleh... can salvage bearings or replace buckled hubs
Also got s13/180sx SR2det stock smic and airbox... $50 each
PM me or call/sms me on 0424 437 054... I hardly check these posts so please don't reply post...
https://www.sau.com.au/forums/topic/236465-got-sum-stuff-lying-around/
    • Here is a recipe. Sonic blocks till you get one that has a good enough bore. Get a torque plate and block brace, use your choice of fasteners (arp ect) bolt the thing together empty, half fill it and let it cure. Release it when it has, go to a REPUTABLE RB Builder and get the thing line bored/honed and cylinder honed to size, then wash. Once its all clean and dandy, wash and blow it out again. Then again.  Assemble said engine to your desired clearances with oil control mods, gasket to suit desired CR/Squish ect. Attach your extended sump with proper trap door oil baffles and head drain plumbed to sump with a SUMP BREATHER SYSTEM. Build your front diff with a decent LSD, rebuild your transfer case with a few extra plates, more than likely replace your tailshaft centre bearing and tighten up the rear diff. Tune to minimise excessive midrange cylinder pressure (timing unless you like to split bores and rebuild engines) Enjoy your engine, but hate the fact you are now destroying engine mounts, gearboxes, gearbox mounts, diff output flanges and driveshafts, diff mounts, tailshafts and front CV's.   Disclaimer.... Ive never done any of the aforementioned stuff.......
    • 440s will support well over 400HP on petrol, which is a decent place to be for an RB20. 230+rwkW. Will be a safer bet for idle/low load. 550s would be nice for the extra headroom. I've made the same decision with mine (Neo25). 1000s are probably too big for the Nistuned ECU, so I have some smaller ones.
    • Appreciate everything guys. I did go ahead and get an alignment... most of my complains are solved. Car is not perfect, but it's good enough. If I notice uneven tire wear or anything I'll just take everything back to stock.  Thanks again!
    • They still have not shipped the 550cc injectors as they weren't in stock, so in theory I could ask to get the 440cc ones instead, if those work better in my scenario. They're the same price so really shouldn't be an issue. Unfortunately I am not so knowledgeable in most parts of tuning so I wasn't sure what's best to choose between the two. 440cc ones are the lowest they have (not in stock, but available to buy nonetheless).
