well it has a stock wastegate. well you can but you need to probably run an exhaust and pod to make the full potential of the turbo.
again its upto you to put extra mods to get more power (injectors, ecu, fuel pump, boost controller)
well you can put it on either rb20 or rb25
and the 2530 is the least laggy out if the hks gt series
https://www.sau.com.au/forums/topic/23675-hks-2530/#findComment-506766
I have a HKS GT2530 turbo to suit RB20, RB25 and SR20
Mr Rb20 they are a great turbo for an RB20. But be sure it is a T3 not T25 flange.
The same turbo cannot fit an SR20 and RB series engine as they have different exhaust flanges.
Forgetting the very latest HKS turbos the HKS GT2510 is the smallest, but typically the 2530 is seen to be the better option.
Oh and it uses an internal wastegate.
Do a search, plenty of happy RB owners using 2530s with stock injectors and re-written ECUs.
https://www.sau.com.au/forums/topic/23675-hks-2530/#findComment-507018
read the last page of thre thread, some RB25 owners weigh in on the conversation.
I have been in a RB25 witha 2530, and i sure dont think its "too small".. its very responsive and can give up to a 50rwkw improvement over std turbo. A great turbo.
https://www.sau.com.au/forums/topic/23675-hks-2530/#findComment-507745
Originally posted by DoughBoy
Skyline33, how can the same turbo be a bolt on for SR20's and RB20/25's since they have a different flange? Unless you have a couple lying around, of course.
from my understand the sr20's and rb (20 and 25) are changable
https://www.sau.com.au/forums/topic/23675-hks-2530/#findComment-508212
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
