Guest Miss_Nismo
$250 ono - [email protected]
Item is new and has not been used. I have used the model below in my car and tested it, it picked up radar and laser gun.
The Whistler DE-1780 includes a built-in memo recorder, and will allow you to record up to 9 messages or 90 seconds of audio. The DE-1780 is also equipped with an easy to read and understand alpha-numeric display. The Whistler DE-1780 provides Whistler's Real Voice™ technology, where you hear alerts from a human voice.
The Whistler DE-1780 responds to all types of radar currently in use by police, and provides 360 degree detection of all types of laser guns laser. The Whistler DE-1780 is immune to some police detectors, and provides alerts when these police detectors are in use. The alpha-numeric display allows for full support of SWS alerts, including detailed information messages.
Whistler DE-1780 Features
(Clicking linked items will open a description in a new window)
360° Protection against all types of Laser
X, K, Ka, and Super Wideband Ka Detection
Safety Warning System (SWS™) Alert
VG-2 Undetectable
VG-2 Alert
Instant-On (Pulse) Detection
Alpha-numeric Display
Memo Recorder
Integrated Real Voice
Stay Alert Feature
Teach/Tutorial Mode
Auto and Manual Muting
City and Highway Modes
Vehicle Battery Saver
Self Test
One Year Manufacturer Warranty
Plugs into your cigarette lighter.
https://www.sau.com.au/forums/topic/23693-fs-whistler-radar-detector/
Guest Miss_Nismo
Originally posted by pushead
how accurate are these? is the band tuned for australia use?
I used to have one, and it saved my arse many a time, it has city mode which will pick up radar and laser gun in australian cities.
Please note they are illegal to use.
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
