Hey Guys/Gals
Just did some searching on here and found a few threads on how to remove a R33 stock spoiler, However i cant find anything that tells he how big the holes in the bonnet are once removed......
Can anyone help, as i was going to get plugs to fill the holes till i can afford to get it filled and painted...
All hep appreciated.
And Please done flame if you have found it in another thread as i HAVE looked but couldnt find it...
https://www.sau.com.au/forums/topic/237036-r33-spoiler-holes/
Good question, i thought about doing this myself, removing spoiler, getting a rubber grommet and spraying white to plug the hole. If its a temporary fix, you could use some really good quality, sticky cloth tape which would do a good job sealing the hole from the inside.
Are you thinking of leaving your car without a spoiler/stealth lip?
Yeha mate wanted to leave it without the spoiler and was going to plug the holes up for a while and eventually would get then filled sanded and painted but yeah cant afford to get that done straight away so this is a temporary change...
Where do you reckon you will get the grommet pluggs from? Mitre 10 or a hardwhare place?
Nice 1.... Tried to remove spoiler on the weekend... was a piss poor attempt really got all the screws undone 6 over all i think there was.... But i was to afraid to rip the spoiler off at its connected to the boost with an adhesive..... I tried to use string fishing line to break the seal, however that didnt work...... Any idea for loosening the adhesive ?
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
