hey guys got a few things i wana get rid of
r32 GTR Rocker Covers(black) $120
R32 GTS-T Igniter pack $80
R32 GTST Power Steering pump $40
R32 GTST Cam Angle sensor $50
R32 GTST Rocker Covers $20
R32 GTST Fuel injectors & rail $60
R32 GTST Timing covers $20
R32 GTST Standard exhaust manifold $15
R32 GTST Inlet Manifold $30
R32 GTST Throttle Body $50
R32 GTST Standard Camshafts $40
All parts located in Melbourne s. e. suburbs
https://www.sau.com.au/forums/topic/237369-r32-parts/
yep i'll take
if they arent deeply scratched or anything :nyaanyaa:
PM me if shipping isnt an issue
https://www.sau.com.au/forums/topic/237369-r32-parts/#findComment-4163750
  • 3 weeks later...
