Make: nissans
Model: cefiro a31
Transmission: manual
Colour: white
Complied? yes
RWC supplied? no
Currently registered? just been cancelled
Price: 10k as is has a spun big end bearing or 14k with freshly rebuild motor may swap 4 rite thing
Contact: pm me
Comments / Modifications: It's a 1990 Cefiro with all electrics, rb25 just put in but motor is knocking(probs big end bearing) come's with spare motor but has same problem, bucket seats, bride drivers seat, momo 4 point racing harness, hks in-cabin boost control, hks turbo time, Defi information computer,r33 box and brakes,blitz blow off valve,hks valve controller, custmon dumb pipe, some braided lines all gauges -temp, oil, oil pressure, boost guage, & fuel air ratio. Engine wise, RB25 and modified computer. After market air flow meter, HKS air pod, aftermarket oil cooler, huge Hybrid intercooler, Huge 3.5' exhaust system. triple plated cusco clutch and flywheel much much more. 17'' wheels,HKS adjustable suspension. Car clean all round inside and out. its a weapon.
Edited by ceffydrifter
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
