funny but its not that bad really
1st spins 2nd a little but nothing major its 4wd dont forget so its pretty good
of course rwd would be just a big mess :bomb_ie:
i only run it on 14psi around town its only seen high boost mabe 3 times hehe
just a weekend car that i have a little fun with
https://www.sau.com.au/forums/topic/237586-r32-gtr/page/2/#findComment-4242521
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
