hello to all out there? some of you all ready know that im a mechanic and have been for a number of years dealing with performence imports of all sorts .
as ive manage to find myself a good cheap all wheel dyno and ive started setting it up in my shed hear at home and few other ins and ends i well be opening up soon hope in about 3 weeks.
ill be dealing from tune most ecu and engine building of all sorts to everyday oil changes and many other things from 4wds to GT-R"s and many other cars and also doing turbo rebuilding if need be? as ill be just starting out at home it well be very limited? but in time if all works out i well open to better doors in time and i well be importing sec hand parts from japan..As im based in hobart well berriedale buy the river front
if there is any thing els i can help u with please drop me a pm
well thank you all and kind regards mich
https://www.sau.com.au/forums/topic/238010-new-work-shop-comeing-soon/
Any experience with Nistune?
yes i can mildly retune factory ecu. but i havent delt with it much.
i can do mines ecu, apexi power fc, nismo, motec, autronic, wolf, michrotec, and many more. from mild to wild depending on your setup. and what u wish to get frome your car and in performance and what u wish to do with your car as a everyday driver to a weekend thing but as to tune most ecu's yes i can do...
i have had a few good talks with Mich and am really impressed with his knowledge and friendliness - best of luck to you buddy :P
oh and here in Tasmania, we spell the word "comeing" without that 'e' in the middle :)
lol...hehe...lets hope he tunes better than he spells.
good luck with it Mich.
I am sure there will be a lot of business for you if you can tune remapped nissan ECU's well!
Best of luck mate, might pop you a PM to give our 99' magna a tidy up (service, clutch etc) coz I can't be effed! :nyaanyaa:
I shot you a PM.
I got a car for you to tune that might give us all a benchmark of your abilities.
320RWKW with out NOS and 400RWKW+ with NOS is my estimate for my R33 so it will be a good benchmark to see how he goes with high power RBs.
Might have to go a bigger turbo so I don't need the NOS to get 400RWKW :)
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
