timing lights are hard to use on a nissan because they don't use standard leads so what i did was get copper wire rap it around the top of the spark plug attach the coil with the wire coming along the side of the spark plug and up from the side of the coil boot then i attached the wire to the timing light pick up. this worked for me.
you know you use timing lights very rarely so do what i did return it after you use it and there you saved $80
for r33 gts and gtst the timing is at 15 degrees from the factory and 20 degrees for the r33 gtr
good luck :cool:
https://www.sau.com.au/forums/topic/238028-timing-light/
I usually have a spare lead to test with for my timing light.
Nissan engines (turbo ones) dont use leads, the coils sit directly ontop of the spark plugs.
So what you dois carry a normal lead, attach this to the plug, then to the coil, and then clamp your timing light onto this lead. When doing timing advvancements and retarding, you only need to measure the timing from the 1st Cylinder anyway.
B.
https://www.sau.com.au/forums/topic/238028-timing-light/#findComment-4165238
  • 3 weeks later...
sorry to bring up a bit of a old thread, how do u test timing on rb25 series 2, do you know what wires to clamp it around?
my cas was facing the wrong way from this engine i got from a importer, so ive turned it around and set it in the middle, so im going to have to play with timing tomorrow when i first start the car, (engine hasnt been started in a few months), will the car just run like crap if timing is right off?
any info would be good,
Thanks
https://www.sau.com.au/forums/topic/238028-timing-light/#findComment-4291274
At the back of the engine where the coil pack cover is there are two loops - one white wire and one white with a black trace. The white one is what you use, but I found that my timing light would fire inconsistently off this because it was expecting a stronger/clearer pulse. Therefore I did the plug lead trick (coil pack -> spark plug lead -> spark plug) for cylinder 1.
https://www.sau.com.au/forums/topic/238028-timing-light/#findComment-4292285
^ that is the way that it has to be done
see i did similar it is just im to cheep to buy a lead so i used what i had lying around
ppl keep bumping my topic lol
Edited by 08yannch
https://www.sau.com.au/forums/topic/238028-timing-light/#findComment-4294023
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
