Item: Tein Coilovers
Age:???
Condition: Good
Price:$1000
To Fit: Whatever you like:)
Jamie 0401-004-999
Comments:
I have just bought a R32 GTR and it came with Teins that are too stiff for me. Apparently they are adjustable but I would lke to freshen the car up with some new coilovers or softer ones for a trade. With a creaky back and used as an everyday driver, I would like to soften the ride for everyday use.
Will trade with good quality softer coilovers.
Cheers
https://www.sau.com.au/forums/topic/238206-tein-coilovers-fs-or-swap/
