I too am shocked.
Id love these wheels!
Unless you want swap stock R32 GTR's with brand new high quality rubber and cash your way, its free bump :blink:
Best of luck!
Thanks mate..
Looks like I have settled on selling the rims to a friend, love these wheels too much to sell for pocket change and never see again :D
So we will see how it goes.
Thanks for the offer thought
Tomek
  • 2 months later...
Back up for sale, friends car went off the road (literally).
$1750 FIRM
Points;
-Immaculate condition
-Extremely high quality wheel
-Roadworthy rubber
-By far the cheapest/ best set of wheels on sau on offer
-Awesome offset
-AUS dollar isn't doing any favours
PM or call 0431 520 274
Tomek
Yeah thanks for the bump :)
Still doesn't change the fact that there a kick ass rim, not everyone does motorsport events or owns a GTR..
They look real tough on GTS-T's.
Would they fit a GTSt they look like the offset would sit right out on the rear. Reason i ask is mine has GTR front guards but the rearis stock and they fill your rear end so think they would sit out on mine.
I've got some pics here somewhere off them on my mate's 4 door, they fit but were scrubbing the tire's lightly.
Will find them after work.
Tomek
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
