Heya all,
Been lurking around here for awhile.. but have come across something funny with my car. Thought i'd chuck it here and see if anyone has any ideas/suggestions etc :thumbsup:
Anyways, the car's a 03 350gt 6mt with 47thou on the clock. I got the car serviced yesterday and decided to dyno it for the heck of it but it returned a rather low figure of 131 kw at the rears. Odd i thought as most are saying stock should put out around 160 at the rears.
I bought the car 2 months ago with 43 thou on the clock and since then it's had brake, engine, clutch, gearbox and diff fluid changed. The oil filter has been replaced. The car when bought, had a kakimoto regu 06 & R y pipe back exhaust installed shortly followed by a trust panel filter then a z-tube.
The car doesn't feel sluggish and in fact, feels quite fast. G-tech gives it a 5.89 time to a 60mp/h dash but 131rwkw seems a bit low for this kind of time. My previous ride was a mazda 3 mps with 180kw atw and that car only managed to post a flat 6 to the 60mp/h dash.
My next step is changing the spark plugs but i doubt that will help.. i think they come with platinum from factory that are good for upto 100 thou km's ?
Any ideas/suggestions etc is welcome!
Thanks for reading.
P.s. If anyone is around the st.george (sydney) area with a 350gt m/t and doesn't mind showing me what kind of power i should be feeling in my car (e.g. torque going up a hill/in gear acceleration), please feel free to PM me. If you'd like, you can drive my car and see if it's lacking a certain something as well.
https://www.sau.com.au/forums/topic/238998-350gt-power-problems-maybe/
despite the low reading but if you can still get 5.86s 0-100 then I'd say the dyno may be configured to read low. Perhaps wrong setting from previous dyno run? that can throw the figure out of whack as well. many other factor can make dyno reading varies from one dyno to another
Hey mate, u dont happen to live in South Hurstville do u? west st? if so, i live just around the corner of u, u can take mine for a spin see if there's any diff to your. :)
Hey all,
Thanks for the replies :)
Yeah i was thinking there maybe was a wrong setting on the dyno.. going through the dyno sheet doesn't tell me much though, other than the usual tire pres setting, correct intake and ambient temp plus the shootout mode was correct at 6 cyl n/a. I hope it was a wrong setting. I know this dyno reads fairly well usually as i've had my previous two cars on there in various states of tune/mods and the numbers it manages to post up seems quite realistic/normal. In saying that, my previous cars were dyno'd by the main mech/owner but few days ago, it was the senior apprentice that ran the 350gt.
BLISTC,
Wow, congrats on your awesome result! Thanks for the offer, really appreciate it but i'll take up GEXer's offer as he's quite close to me.
GEXer,
PM incoming, thanks mate :D
nothing - completely stock
ill try get the dyno graph posted
was done at a dyno day this yr @ unigroup engineering in girraween
Oh, ok...
I would of thought that was a bit high, but I may be wrong.
Not by much though!
Just an update if anyone is curious..
GEXer took my car for a spin and noted that 1st gear felt better than his but my 2nd gear was weaker. GEXer's v35 however, has a different diff in it i believe so it was kinda inconclusive.
Been driving it around lately giving it a bit, certainly feels more than 131kw atw, so i don't really care.. long as the car is running healthy which it seems to be. AFR check was ok.
One thing my mate spotted (he was there during the dyno run) was that it was a raining day and my car went on with wet tires, plus the person driving my car on the dyno thought it was wheelspinning (the speed did climb a bit quick.. i've thrown my cars on the dyno plenty times) so most likely that explains the low power readout.
Case closed, am happy. Under 6 sec to 60mp/h timing is repeatable too without being super brutal so i think the car is going ok.
P.s. Thanks GEXer! Really appreciate it. Btw, saw your V35 today, very nice looking!
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
