Hey guys got a few things for sale
set of white Emotion CR kai's all 4 are 17x9 +17 offset and 5 stud. $2000 never used brand new in box, two wheels come with new tyres as well
A 88 cefiro with rb26dett out ofa r32
Mod plated so can be registed also mod'd for full roll cage, bucket seats
has late model tail lights
s15 dash
stripped interior and sound deaden
rear strut brace
all panels are in primer has all glass
missing suspension, brakes and diff at this stage but will be sold rolling.
Im the only owner of this car since its been in aus.
engine has
turbos off a 34
rb25det gearbox
orc twin plate clutch
Power Fc with hand controller (brand new)
Sard 700cc injectors (brand new)
oil cooler
PWR alloy radiator
Blitz twin bov
Apexi air filters
timing belt was changed when arrived in the country and has been well maintained.
$ 10000 for the whole car not really looking to seperate anything at this stage.
contact me on 04433776673 and im located south brisbane.
https://www.sau.com.au/forums/topic/239058-work-emotions-rb26-cefiro/
List of a few things SOLD
Power fc and hand controller
Rb25det box
oil cooler
pwr rad
twin plate clutch
Stil got the rb26dett for sale 3500ono
work wheels emotion without tires for 1700
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
